3247 Holly carb./66 - NCRS Discussion Boards
3247 Holly carb./66
  • Dennis D.
    Infrequent User
    • March 1, 1991
    • 8
    3247 Holly carb./66
    On a search to purchase a original 3247 holly for my 425 hp 66 car, my questions are: what does the El or A or nothing behind the GM part #3886101 stand for? What are the #'s on the front and rear metering blocks supposed to be? I located one with a 3/4 " x 1/2" piece broken off and repaired on the top of the airhorn above the part#'s and date area. How is this type of metal repaired and what points would be taken off for condition. The repair is very visible. thanks.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 3247 Holly carb./66
    avoid the repaired air horn esp if the repair is very visible . Counterfieters have been know to remove later service date 3247" and then attempt to re-stamp an appropriate date code to fool the judges. judges look at this area of a holly to see if there has been any tampering and if the repair on the carb you're looking at is in the same area the judges will be suspicious.
    • Clem Z.
      • January 1, 2006
      • 9427
      pri metering body 4901A, secondary 4519A
