Hello folks its been a while since I have needed your help.I own a 1966 corvette and have a question on what should the correct rear end case cover's part number should be.My car has a build date of October 28th of 1965
I was told my cover should be 387135 with no date coding punched into it by the filler plug,So now I am calling around trying to find a correct rear cover and then I was told by a used part supplier that NO your rear case cover should be a 3830303
The cover thats on the car now is a 464910 and I had a broken cover that came with the car that the last owner snapped installing the rear spring,I threw it out and never kept it because I fealt it was un-reparable
When I first bought the car I used to think numbers ? what numbers are they talking about? So now I am learning little by little what numbers are all about.Quite exspencively when your looking for the correct number I may add.
As alwaays thanks in advance for your help
thanks Larry
thanks Larry
