I am installing a distributor back into my motor but it doesn't seem correct. I took a photograph of the cap with wires installed and a picture of the position of the rotor before I removed the wires and distributor. I am certain I put it back in exactly as it was (the motor was never cranked while the distributor was out). The AIM clearly indicates the #1 firing position on the distributor cap but when I am at top dead center (both valves on #1 are closed) my rotor points to approx the 8 to 4 position. Also the timing mark on the harmonic balancer is not at zero degrees. I also noticed that I appear to have two timing marks one that is a white line and one that is an actual groove in the harmonic balancer which I believe that is the timing mark I should use?
To install this correctly should I remove the distributor and turn the oil pump so that when I reinstall the distributor it will mesh with the slot and my rotor should be pointed at the number one position on the distributor cap? Am I overlooking something? HELP!! Thanks
