C-1 bandjo axle question - NCRS Discussion Boards
  • John S.
    • July 31, 1990
    • 292
    I was told that the bandjo axle for posi. unit's from the factory had a baffle in it. Is it ok to put a posi unit in a bandjo axle that orginally had a open rear end with no baffle? Thanks for any help. john
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C-1 bandjo axle question
    John, I assume you are referring to the 2 large flat washers that the axles go through just before they index into the center section. They were just tach welded in place. I do not know if they were unique to Posi housings. In any case, I can't see why it would hurt to install a Posi unit - I'm sure it happened many times over the years.
    • roy braatz
      The baffles were to keep the oil from pouring down the side to the axle bearing on those 90mp turns of 90 degree.
      • Gary Chesnut
        In addition to the tube washers - there is an on slinger/dripper baffle in the top of the banjo housing. For hard driving would recommend a posi banjo housing which will keep the ring gear bathed in grease. For limited street driving and NCRS events, a non-posi unit should be just fine. Regards, Gary #5895....
