Does anyone know the correct configuration for the undercar exhaust clamps (center cross-member, connect to the mid-support by the transmission mount) for a '66 L79 2 1/2 exhaust? The ones I have seen from LICS or Paragon do not purport to be correct and have a fully round u-shaped upper part of the clamp. I have also seen some where the u-shaped upper part is flattened where it goes over the center support (and then rounded where the threads are). The bottom part (connected to the upper part by the nuts) appears to be the same for both. Thanks.
Larry
Larry
