Jack Suggestion - NCRS Discussion Boards
Jack Suggestion
  • Rick A.
    • July 31, 2002
    • 2147
    Jack Suggestion
    Folks,
    Just called the local Chebby dealer and found out you can still buy a jack for a 1963! Price is $178.00 plus taxes and of course they need to order one. Well, I personally don't want to spend that kind of money for a scissors jack to take with me on the drive to BG with the caravan. What kind of jack would this "august" group recommend? A scissors type from Manny, Moe and Joe or those other outfits? Carry a bottle jack and piece of wood? Open to any relaitvely inexpensive alternatives.
    FYI - I have a "correct" jack for NCRS purposes but it is not meant for jacking!
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    Re: Jack Suggestion
    Some of the parts folks at various Chevy dealerships are 'hip' to licensed reproduction parts. It wouldn't be the first time a fella ordered something and got a repro....
    On traveling, I carry a bottle jack in addition to my original and HAVE used the bottle jack once/twice. Depending on size/style you purchase, it will work without having to 'shim' and folded shop towel will safeguard against scrape marks to your frame!
    • mikemccagh
      Re: Jack Suggestion
      Bottle jacks i've seen too tall to fit under C-2 frame with flat tire. the GM currently availabe probably not even close to original and way too expensive for your purposes. If manny etc can supply a scissor type for reasonable price , go that way. Junk yards good source. try old corvairs but you'll have to weld a 3 by 5" plate on a corvair type to accomidate the flat underside of C-1 frame. good luck, mike
      • Rick A.
        • July 31, 2002
        • 2147
        Re: Jack Suggestion - Jack/Mike - THNX! *NM*
        Rick Aleshire
        • Rick A.
          • July 31, 2002
          • 2147
          Re: Jack Suggestion - JFOLLOWUP!
          DOH!!!!!!! Just realized that Carlisle - All GM is this weekend! I can probably find a jack there! DOH!!!!!!!!!!!!
          Rick Aleshire
          • Mike Sasser
            try this link for a scissors jack
            • Rick A.
              • July 31, 2002
              • 2147
              Mike - thnx looks like what the doctor ordered!
              Rick Aleshire
              • Christopher R.
                • March 31, 1975
                • 1599
                I bought one of these for my C1. Made in the USA. Around $20. Fits in the spare tire well just like the original. Allows use of board hold down bolt, just like original. Made by NORCO who took over the manufacture of AUSCO's jacks. Hmmmm. AUSCO made the original.
                • Rick A.
                  • July 31, 2002
                  • 2147
                  re: Jack Suggestion - Followup
                  went by the local AutoZone (think it was) and they had a 3300 scissor-style jack on sale for Father's Day at $17.99 plus tax - one of them now occupies a space in my 1963 Z06 compartment
                  Rick Aleshire
                  • Doug Flaten
                    I got the China version. I guess it depends on which one they pull off the shelf.
