If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Recently had my '57 start pullng to right upon braking. Found the right front wheel cylinder was leaking. I rebuilt it, bled system and adjusted brake. I cleaned the drum and shoes with isopropyl alcohol but it still pulls. Do I need to replace the shoes (about 1/2 life left) or will it burn out eventually?
Ted
with Mike. If you got lucky and caught the leak before the brake linings were REALLY impregnated, you might be able to 'sand' enough surface off to get back to a solid abrasive lining. If not, regardless of how much pad is left, it's time to discard and replace....
I dunno if I'd even drive that 50 miles. Since you already have the car jacked up and the wheel off, that's half the labor and brake shoes are cheap.........
Jack,
I has been awhile, but was able to pull off front spindle and sand down the show some as well as the drum. Cleaned up with alcohol and reassembled and adjusted. They work fine not. Thanks for advice.
Ted
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
