1957 Gas Tank Filter Replacement - NCRS Discussion Boards
  • Dan Wichlan
    There is a black cloth glued over the gas tank access panel under the soft top. How can I loosen this without tearing it and how do I reattach it?
    Is there any trick to removing the sending unit from the tank?
    How does the "sock" filter attach to the sending unit intake line?
  • Rob Dame
    Re: 1957 Gas Tank Filter Replacement
    Dan,
    You can try soaking the mat with 3M Adhesive Remover then peeling back the edges gently until you get to the screws.
    I'm not sure if that will work or not. You may be better off cutting the mat around the edge of the tank cover
    The sending unit will come out of the tank by lifting and rotating as needed
    The filter just slides on the end of the sending unit tube.
    Rob
