after resoring my 67 , i'm going to drive it this summer with a fresh 396. Can i put my rectangle intake on the oval port heads? Are there any special gaskets for this? Years ago i turned my 427 into a drag engine 121/2 to 1 I have never started it since.Thanks again Rich
c2 tri power ?
Addendum
I have installed 435 intakes on 400/390 hp engines. There is no fit problems typical to this installation but you might provide more fuel than a low horse 396 may handle, a 360 hp 396 would probably work or any 396 with cam and ignition that can fire the mixture.
jer- Top
Re: Addendum
thanks Jerry, I'm using a402350hp right now until i get the 427 ready.Also do know if using open chamber heads on my closed chamber427 could it lower my comp.? my 427 is 121/2 to 1 30 over, if not i'll probly have to change pistons again. Thanks again Rich- Top
Re: Addendum
if you do not know the ccs of the heads and pistons post the casting/part numbers and i will see if i can help- Top
