Hello all. My '72's parking brake does not want to hold. I have tried adjusting them at the equalizer (where the brake cable "Y"'s out, about 2/3 of the way back underneather the car). This did not help. Someone sent me instructions on how to adjust the parking brake by removing the rear wheels, loosening the equalizer nuts, and then sticking a screwdriver into the holes in the two rear hubs, and turning a little cogged wheel. The problem is, I can not determine which way to turn the wheel. Should it be turned up or down, in order to tighten? And please don't say "righty tighty, lefty loosey"! There's no way to determine which right or left, as all you can see is the little cogged wheel itself.
Thx,
Kevin #39927
Thx,
Kevin #39927
