Job Numbers? - NCRS Discussion Boards
Job Numbers?
  • Dick G.
    • May 31, 1988
    • 681
    Job Numbers?
    Has anyone ever deciphered the job numbers on these old corvettes? My 1965 body is off and I am finding job numbers as I clean, and wondered if anyone has info. on them? Under the gauge console, on the bar, I have in white 8327, on the bulkhead in front of the gas tank in red E263.I believe, there should also be a number on the firewall (engine side) under the previous owners black paint. Is there anywhere on a midyear where the factory left a body color notation in writing like on some straight axles? Thanks
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Job Numbers?
    Try looking on each inside door (on the fiberglass that would contact the vinyl door panel). Maybe middle lower area, on a flat surface below the door pull mechanism. Should be same as facing gas tank, and passenger footwell (engine side). Jack H. reports #'s also under fiberboard headliner on hardtop optioned cars.
