In viewing other POPs, I see that '69 and up the interior & paint codes ARE NOT on them. I guess I thought this was standard as the two original '68 POPs that I have, have the interior & paint codes on them. Anyone else have an "original" 1968 POP and notice this???
1968 Protecto Plate info...
Re: 1968 Protecto Plate info... *TL*
Paul,
Yes, as you have noticed, the PoP is another 1968 difference. If you have the 1968 Owner's Protection Plan booklet you will also notice some significant differences between the 1968 and later documents, not the least of which is that the 1968 version has tear-off maintenance pages with the VIN punched through the form. I wonder why that changed for later years?
BTW: This is not a Corvette only feature, I have seen it for other 1968 Chevrolet car lines.
Terry- Top
Paul-----
1968 was the last year that interior and paint codes were included on Protecto-Plates. 1969 through 1972 did not have the interior and paint codes. After 1972, the Protecto-Plates disappeared, entirely.In Appreciation of John Hinckley- Top
I have my 68 chev owner prot plan book for chevelle camaro chevll corvair corvette in my hands.page 1 thru 5 warrenty info, 6 thru 7 maintenance,8&9 policy,10&11battery,page 12 maint schedule, 13 record of required maint,14&15 tires.Tear off starts on pg 15 & goes thru the 48 month validation to pg 22. 23&24 are delco pages. the last page is the hard page w-the pop.Nowhere do any of the tear off pages have the ID# on them. Last page also has date of service. Where would I find the ID# refered to on repley. Or am I confused. Thanks for the help. Curt.- Top
The 1968 Corvette and Chevelle Protection Plan booklets I have seen, which came originally in new cars have the vehicle VIN number punched right through the entire booklet, all pages at the far right hand edge - as you look at the closed booklet. It is hard to miss.
Terry- Top
This is Correct on my two '68 Books...
Vin is punched through every page except the POP page. First # of the VIN(a 1)is at the top then comes down along the right edge of the pages. Also a row of "larger" holes or "dots" about a 1/4" UNDERNEATH the VIN. 13 in all. One for each character/number in the VIN.- Top
As the original owner of a 1968 Convertible, I have the original POP. It has the VIN number punched thru all pages and the trim and paint codes are on it. By the way, the original warrantee required that the car be checked at a dealer at 12 month intervals and a coupon removed from the booklet. The booklet says that it is applicable to chevelles, camaros, chevy II's Corvair's and corvettes.Jim Boudreaux
LA Chapter, NCRS
_____________________________
1968 British Green Convertible 327/350HP Original Owner
2002 Z06 Black on Black Original Owner
2007 Z06 Velocity Yellow w/Black/Titainium Original Owner- Top
