66-67 Grille - NCRS Discussion Boards
66-67 Grille
  • Dave K.
    • November 1, 1999
    • 951
    66-67 Grille
    Which way do the rivets fastening the brackets to the grille go? Are they with the head on the inside ( as I suspect)and the crimped side visible or with the rivet head outside and the crimped side non visible?
    DAve Kitch
    33108
    Re: 66-67 Grille
    Dave -
    I don't have my car to look at right now, but the A.I.M. shows the head of both rivets at the top, with the crimped end at the bottom.
    • Peter L.
      • May 31, 1983
      • 1930
      Re: 66-67 Grille
      Dave - The grill bracket rivets on the grills (which I believe to be the original grills and brackets) of both my '66 and '67 were assembled per the AIM information John provided. Large head (top) and crimped end (bottom). Pete
      • Dave K.
        • November 1, 1999
        • 951
        Re: 66-67 Grille
        Pete,
        My 66 assembly manual differs from the AIM. However, does you cars show the round part of rivet on top for both the upper and lower rivets?
        Dave Kitch
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1464
          Heads-up *NM*
            Re: 66-67 Grille
            Dave -
            A.I.M = Assembly Manual (same document); shows the round head of both upper and lower rivets at the top, peened-over ends at the bottom.
            • Peter L.
              • May 31, 1983
              • 1930
              Re: 66-67 Grille
              Dave - Yes, both rivets are installed in the same manner.
              And John and Mike thanks for clarifying.
              Pete
