C1 Clutch Linkage - NCRS Discussion Boards
C1 Clutch Linkage
  • Christopher R.
    • March 31, 1975
    • 1599
    C1 Clutch Linkage
    Any tips on how to improve or maximize the performance of C1 clutch linkage?
  • Gary Bishop
    Re: C1 Clutch Linkage
    Have you checked the ST-12 Service Manual to see if you are set in the long or short throw position? Page 6R-3
      Chris -
      1. Make sure clutch pedal pivot shaft bushings (up inside pedal support) are in good condition and are well-lubricated (Lubriplate, etc.).
      2. Captured bushing in good condition where pedal pushrod attaches to the top lever on the cross shaft.
      3. Ditch the "Godzilla spring" and replace with a conventional return spring to the firewall a la C2.
      • Dennis A.
        • April 30, 1999
        • 1010
        Godzilla spring
        John...
        Can you provide a few details for replacement to a conventional spring?
        Size & length of spring and how & where do you attach to the firewall etc.
        T.U.
          Re: Godzilla spring
          Just unbolt the upper bracket (2 bolts) from the upper arm on the cross shaft, and replace with a coiled return spring anchored to the top bolt hole on the lever and to the firewall. C2's use a neat little hook to anchor the firewall end of the spring under a bolt head. All the spring has to do is to hold the pedal up against the rubber stop bumper on the pedal support. The Rube Goldberg "over-center pedal assist" arrangement isn't required with contemporary clutches, and can cause problems with them. It's a simple "put-back" if you want to have the car judged.
