I am filling a rebuilt differential on my '67. Relative to the filler plug, what is the proper level, and will it need to be topped off after the car is driven for the first time?
'67 REBUILT DIFFERENTIAL FLUID LEVEL
Re: '67 REBUILT DIFFERENTIAL FLUID LEVEL
The actual spec should be in the owner's and shop manual, but I think it is between the bottom of the fill plug to 1/4" below. If you fill it to the bottom of the plug when cold, it will be a little higher and spill out when hot due to expansion with temp.
The specified capacity is 3.7 pints, so you could put this much in and if it's between the bottom of the plug to 1/4" low, it's okay.
Duke- Top
