'67 SUPPORT POINTS - NCRS Discussion Boards
'67 SUPPORT POINTS
  • Rob A.
    • December 1, 1991
    • 2126
    '67 SUPPORT POINTS
    I just had to reshim the body and the radiator support on my chassis because I installed it while supporting the frame under the door areas. The frame was sagging in front from the weight of the engine and when I lowered it onto the wheels the radiator support to area changed significantly. That being the case, where should the frame be supported in order to work under the car without putting stress on the front area?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: '67 SUPPORT POINTS
    The car should be supported as if it were resting on its tires. Why not install your wheels and tires, then block all 4 of them up, to make it easier to get underneath.
    • Dick W.
      • 10483
      When I worked on a car on the lift for a significant length of time (body on restorations), I would use a set of tall axle stands, placing them under the frame at the control arms and if the rear suspension was still under the car at the end of the rear springs, if suspension was out I would support the rear right in front of the kick up. I had no problems with door alignment if I did it this way
      Dick Whittington
      • Rob A.
        • December 1, 1991
        • 2126
        The car is resting on the tires now. I've never supported a car by placing something under the tires, is that what you mean?
        • Dick W.
          • 10483
          I meant support it by the frame and suspension. That way you can remove the tires.
          Dick Whittington
