Big block L/89 engine lifting process - NCRS Discussion Boards
  • Steve Antonucci
    I have a little question for those of you that know L/89 optioned engines.
    What are the recommended mounting locations for the chain or harness for
    hoisting an aluminum headed big block? The years I am interested in are
    1967 through 1969. I know that L/89 eguipped engines in non-Vettes
    use one steel bracket on the left front ( two bolts ) intake and another
    on the rear of the right head. Corvettes still used the short water pump
    in 1969, so I'm not sure where the factory hoist locations were.
    Once I finish building my aluminum headed L/71, I want to be sure I don't
    rip the threads out of the heads. This monster seems too heavy to chance
    lifting by three 3/8-16 UNC bolts in aluminum.
    Can anyone suggest the proper way? Is the factory way the safe way to go?
    Too much invested to take the chance!
    Steve
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Big block L/89 engine lifting process
    every engine i ever built both SBC and BBC i lifted either by a stock chevy bracket bolted to the 3/8" intake bolts or 7/16" bolts in the end of the cylinder heads. i have installed them in race cars using a plate bolted the the carb flange of the aluminum intake manifold when equipted with a 4 barrel carb using the 4 5/16" carb mounting bolts.
