C2 Convertible Side and Vent Glass Codes - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    Re: C2 Convertible Side and Vent Glass Codes
    Mfgr code is different from date code. The date code is the dual alpha sequence that's defined in the JG book tables. Mfgr code identifies who built the glass, in this case LOF....
    • Wayne M.
      • March 1, 1980
      • 6414
      Dave -- the M54 manufacturer's code (found under the "solid tempered" line) was independent of the 2-letter date code. Date codes are same for windshield, side windows and vent windows.
      Sounds like you have a '66, but my early '65 (tinted) coupe has NO manufacturing (M54) code on the rear glass [JG]; none on the left side [IG], and probably none on the right side [UG]. I say probably, because the stencil was etched so low on the glass that it could be buried in the channel. My late (tinted) '65 convert. DOES have the M54 on the side window [IJ](singular, as only my RH is original). The vent windows, both early and late, have the M54 on the 3 out of 4 that are original.
