63 FI Air Filter Element
  • Joe S.
    • August 1, 1999
    • 319
    #1
    I have the complete housing and S-Tube for my FI Unit, but the filter I have is an old aftermarket (dirty) paper repro. Does anyone have a suggestion for some alternative filter?
    I've called around and an NOS is available but close to $500. BEfore biting that bullett (big ouch) I'm sure there is some other solution available (I Hope).
    Joe..
    Joe and Joanne's 63 FI Convertible
  • Danny Pantuso
    Re: 63 FI Air Filter Element
    Hi Joe, corvette central has the foam only for $24.00, but the cage you might have to look for one, check with paragon they might have a use one, good luck Joe, Danny
    • Joe S.
      • August 1, 1999
      • 319
      Paragon has the foam filters for $20 but has no cages. If I had a drawing or good pic of one I could probably build one (with some help from my friend who owns a machine shop).
      Thanks for the info. I may give them a call regardless.
      Joe..
      Joe's 63 FI Convertible
      • Bill Jackson
        I can send you a photo if needed but making one exactly like the original would be a ton of work. You would need to stamp or spin the end pieces then find the correct expanded metal for the body. A workable but not correct appearing one could be built in a day to allow you to use the repro foam.
        • John C.
          • January 1, 2001
          • 171
          The Vette Vues fact book has photos of the cage on page 54.
