C1 shifter lock out T bar problem - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    I have always had problems with the reverse lock out T bar on my 62 4 speed. I have it apart now and see why. There is nothing on my car to pull it down. Is something missing? It looks like they expected the weight of the bottom part to pull it down.
    I put the whole assembly in my degreaser tank, then put some WD40 down the cable and it still does not just fall down.
    thanks, Chris
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 shifter lock out T bar problem
    It is pushed down by a spring inside the chrome shield around the shifter lever. The spring is wound around the cable that connects the blocking pin to the T handle
    Bill Clupper #618
    • Chris H.
      • April 30, 1990
      • 817
      I assume that the spring is not visible.
      Paragon sells the T assembly but no spring is visible.
      Is there a way to repair/replace the spring?
      • William C.
        • May 31, 1975
        • 6037
        Assuming you disassemble, I don't know that you couldn't wind a new spring onto the cable, although I haven't done it myself. I have seen an occasional NOS T handle assembly with spring for sale.
        Bill Clupper #618
        • Chris H.
          • April 30, 1990
          • 817
          Ok, I took apart the shifter and removed the cover. The spring is in 4 pieces and I will look to find a replacement.
          Thanks for the advice. I would never have figured out how this thing is supposed to be taken apart and that a spring was in there.
          Anyone have an idea where I could find a proper spring?
          • Don H.
            • December 1, 1981
            • 1482
            It has been many years since I did it but I think I used 2 or 3 shorter ones to achieve the desired pressure. Don H.
            • Doug Flaten
              My shifter has had similar problems. If I remember correctly, there are a couple of punched in tangs on opposite sides of the spring cover that serve to retain the spring in its position and limit the travel of the sliding block. I think sometimes the block can be pulled up too far and kind of gets stuck up in the housing cover. The cover can get bent out of shape too. These items may need attention in addition to the spring.
              Doug
              • Chris H.
                • April 30, 1990
                • 817
                Paragon can get the spring and pin for a total of $7.00.
                thanks for all the help.
