C2 Clock repair - NCRS Discussion Boards
C2 Clock repair
  • Jerry G.
    • April 1, 1985
    • 1022
    C2 Clock repair
    I recently cleaned and reinstalled my old original clock in my 65. It ran for a little while and then stopped. It will run for a short time if I turn the adjusting knobs. I have heard stories about "burned" points. Can this be cleaned or repaired ? Is this a do it yourself thing or is it time to send it to a clock Doc.
  • Mike Cobine
    Re: C2 Clock repair
    It is pretty straight forward on the repair. Here are the directions.
    http://www.vettenet.org/midyrclock.html
    Midyear clock repair
    • Darwin Kuhlmann
      Re: C2 Clock repair
      Hi Jerry,
      My points were badly burned. I couldn't find replacement points, from the original manufactuer( they were available at one time from Eckler's and from the company- there is an NCRS article about clock repair and has the manufactuer's address etc.) Sooo I put a small electrical soder drop on each contact and filed them flat and it has worked without a problem.
      Darwin
      • Jerry G.
        • April 1, 1985
        • 1022
        Re: VERY CLEVER *NM*
