Garage Floor Paint/Epoxy Coatings. (Suggestions?) - NCRS Discussion Boards
    • 11608
    Re: What year Corvette is that?!!
    John's is 2500 sq ft.
    Patrick
    been there, walked on it
      Re: Garage Floor Paint/Epoxy Coatings. (Suggestion
      Pat -
      Mine was a freshly-poured new floor; I let it cure for three months, then had the steel shot-blast and epoxy coating done. The shot-blasting does two things - gets it absolutely clean, and removes the "skin" on the concrete so the epoxy has open pores in the concrete to bond to.
      • Earl G.
        • September 30, 2001
        • 66
        John,
        Is the surface of the floor slick after the application and/or does any water make the surface slick?
        Gunner
          • 11608
          I don't think Art's barn floor was very old either, and he had the same system installed. When we all visited last June, it was quite recently applied.
          Patrick
          • John M.
            • January 1, 1999
            • 1553
            Gunner,
            I don't know that the floor is any slicker than the polished concrete that it replaced. I wet sand on cars in the shop all the time, and have never had a time where It felt slippery. I do have Tennis shoes on whenever I am out there, so it might be more so with regular shoes. There is an additive that can be broadcast before the final coat to give more traction, but I didn't use it since I wanted as easy-to-clean a floor as possible.
            Regards, John McGraw
              Earl -
              I had them very lightly sprinkle some fine silica sand (NOT "play" sand) in the final epoxy coat before it cured, which provides some anti-slip when the floor is wet. Doesn't interfere with sweeping it - I use a push broom with long, soft splayed bristles, wet or dry.
                Here's a shot of the finished "Home-Pro" epoxy floor in Art's "barn"; he had flakes put in the final coat that aren't apparent in this shot - see the separate link below for a closer shot that shows the flakes.
                • William Holder
                  Hello
                  Are there any problems with Jackstands and floorjacks etc making marks in the finnish? Are these working (ie engine trans removeal rebuilds? or just storage garages?
                  Bill
                    I drop LOTS of things, and haven't been able to hurt it yet; automotive chemicals (including brake fluid) don't faze it either.
