64 L76 crank and balancer - NCRS Discussion Boards
  • Jack Beebe
    My balancer needs replacing (85k mi.) and I'm told it's a press fit on the crank but the keyway is worn so I need a new crank and balancer?
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 64 L76 crank and balancer
    a good shop can weld up the crank keyway and then recut it. they can also cut it for a wider key and mill the new key down on both sides to the orignal width where it fits into the damper groove
