Wow guys, great discussions earlier about heat transfer! I enjoyed it. I am another engineer trying to remember my heat transfer courses. Won't bring in any more equations, or unit analysis, just my own two cents worth, just because I enjoyed the discussions.
Whether or not the heat transfer is taking place in the block, or in the radiator, the process is a kinetic process, which implies a rate, which means time-dependence. Example: use BTU/sec as the heat transfer rate; the more seconds you multiply by, the more BTU transferred. Both heat transfer locations are related (the block and the radiator), and as the coolant temp approaches max, the differential is smaller, and the system should eventually reach steady state. I believe that when all parts in the system are new, the flow the water pump can deliver over its entire speed range will not be an issue. But on an aged system, even considering only the coating of the inside of the radiator with scale etc., the radiator's ability to transfer heat (it's efficiency) is reduced and the water jackets of the block become coated, limiting their heat transfer efficiency also. Consider this; if you filled your radiator with hot water, and it was not circulating and you blew air through the fins, the longer the water sits and the air blows, the cooler the water becomes until it reaches a steady state minimal temperature dependent on ambient conditions and the latent heat properties of the coolant. This seems to indicate that if water is going through a radiator "too fast" and it's efficiency is not "as new" you might encounter higher temperatures at higher circulation rates IF and only IF the original system's design specs are exceeded due to aging of any of the components. This is compounded by the coolant residence time in the block also, as someone previously mentioned.
Just my own thoughts based on a poor memory. And, just for fun!
