Carbs for my 65 Vette - NCRS Discussion Boards
  • Murray S.
    • May 31, 1990
    • 72
    I have just returned from Spring Carlisle, where I found 2 Holley 2818-1 carbs, the first one with a date code of 483 (1964, August, 3rd week) and the second one with a date code of 492 (1964, September, 2nd week). My engine (L79) has a casting date of I 12 4 which I read to be September 12 1964.
    Which carb should I use? Should the carb date pre-date the engine block, or be the same as the enginge block, or should it be nearer to the build date of the car (in my case, November 1964)? When I read the relevant section of the NCRS Judging Manual, I did not find any information explaining how much of a difference in date codes for carb vs engine block.
    There is a substantial price difference between the 2 carbs (approximately $200), so this also a factor. Regardless of which carb I purchase, my intention is to have the carb professionally rebuild by Bob Kunz.
  • William C.
    • May 31, 1975
    • 6037
    Re: Carbs for my 65 Vette
    CArbs were installed at the Assembly plant, and thus have no relationship to the engine build date. The only requirement is that it predate the final assembly date of the car by a week or so, more is ok.
    Bill Clupper #618
