'54 mystery no-run condition - NCRS Discussion Boards
  • Wayne Kever
    I was trying to fire the '54 for the first time since last November. It starts with the starting fluid. Once it ran maybe 15 seconds. Now it only runs 2-3 seconds.
    It has gas, and there is pressure in the fuel line to the carbs. I pulled the top off one of the carbs, and there is gas in it. Not sure if it is the right depth. How deep should it be in the well? I can't find the carb rebuild instructions.
    I disconnected the fuel line and let the gas drain out, then started it again with the fluid. After it quit again, I opened up the fuel line clamp right before the carbs, and gas shot out.
    I'm quite stumped. There is gas, spark, and air. The only thing I can think is something is wrong inside the carbs. It ran great last fall though.
    Any suggestions?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: '54 mystery no-run condition
    Old gas.
    • Wayne #30311
      Really? I didn't know old gas could cause the car to refuse to run completely. Some of the gas is pretty old, but it looks and smells normal.
      • Wayne #30311
        Would you expect that draining and replacing the gas, including in the fuel bowls, would clear things up? Or will I have to rebuild the carburetors too?
        • Jim T.
          • March 1, 1993
          • 5351
          I would not rebuild the carbs, I would first try all new gas.
          • Wayne #30311
            Thanks, Jim. Worked fine with fresh gas. Now it is smoking to beat the band, but I think that is from the "top engine lubricant" that the starting fluid contains.
