If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
If the conventional grease and the synthetic grease are both lithium based, there will be no compatibility problem. If the bases are different, then, technically, the greases are incompatible. However, for a low speed application like u-joints it really shouldn't be a problem.
If it were me, though, I wouldn't mix grease types. That's why for my car I use GM #12377985 for all chassis applications except wheel bearings and Valvoline SynPower Synthetic grease #985 (meets GM spec 1051344) for wheel bearings. I keep one grease gun filled with each and clearly labeled as to which it contains.
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
