Re: Engine ID
The 1/8" NPT pipe plug was used at Flint Engine to plug a drilled oil gallery hole their machining process required; Tonawanda used a different machining process for the oil galleries which didn't require the intersecting hole drilled externally, so they don't have the hole or the plug.
