I'd forget the carburetor secondaries for now
You can disconnect them and the primaries will run the tachometer needle off the scale. I agree with Pete but I'd also check the ignition (points and plugs specifically). Bad coil or condenser. Main feed wire at the bulkhead connector. It's not stated if this came on gradually or it happened after the carb rebuild or what. Lot's of blanks to be filled in here.
