Removal of broken dip stick tube
Re: Removal of broken dip stick tube
How about packing broken tube full of wadding and pushing down a half inch or so. Then tap the ID of the broken tube with an appropriate sized tap. Get a pc of tubing larger than the OD of the broken tube and insert a bolt thru it and into the tapped hole. As you tighten the bolt it should extract the broken tube providing the tube pulls out rather than turns. Just be careful to get packing in good to provide a barrier to shavings from the tapping process from getting into the bottom of the engine. Just think every step through regarding tap depth, bolt lengths etc. Might be a better way but this has worked for me.- Top
Modification of a good idea
This sounds like a good idea. Of course the tube may turn and not pull out. If so, then here are two ideas.
1. Get a longer full thread bolt.
Thread a nut and washer near the head. Then insert into the larger tube and thread into the broken tube. Instead of turning the bolt after you thread it into the broken tube, tighten the nut and washer against the tube to force the bolt (and hopefully broken tube) up and out. Lube all well before starting.
2. Get a threaded rod that fits what you tapped the tubing for. Slide a weight on the rod, like the handle of a slide hammer. put a couple of large washers on the top end of the rod, along with a couple of nuts. Better would be a threaded coupling (like a really long nut).
Then a few pulls with the slide and the tube should pull right out.- Top
Re: Modification of a good idea
Mike--- Your number 1 process sounds dead on. I have pulled three of these in the past with just the bolt sleeeve process and have not had one turn yet but your idea takes that potential problem out of the picture and is easier. With your deal and holding the bolt with an end wrench while turning the nut with another a linear pull would be assured. If the previously tried E-Z out process has not garbaged things up too much it should be a snap for Scott.- Top
Joel:
I had considered threading the tube and using a bolt. I took the new tube to the hardware store and tried to find a bolt which would fit the tube. However, I could not find a size which would work. What size bolt did you use?
Scott- Top
Joel:
Scott- Top
Gents,
A idea to try before tapping (or if tapping isn't possible) involves the previously mentioned slide hammer puller.
My Harbor Freight slide hammer puller has an adapter that allows it to be used with a pair of Vise Grips. You replace the srew in the VG's with this adapter and latch down on the item to be extracted. The slide hammer puller is then threaded into the adapter. Finally, you bang away business as usual. Sounds like it might work for this application.
Good luck,
Gene- Top
Gents,
Good luck,
Gene- Top
