Removal of broken dip stick tube - NCRS Discussion Boards
  • Joel M.
    • May 31, 1975
    • 141
    Re: Modification of a good idea
    Scott-- I'll find my rig tomorrow and let you know.
    • Joel M.
      • May 31, 1975
      • 141
      • Joel M.
        • May 31, 1975
        • 141
        #18
        Scott------- I checked today and it appears to be a 10mmx1.25 - hope this helps---- regards/Joel Miller
        • Joel M.
          • May 31, 1975
          • 141
          #19
          • Chuck R.
            • April 30, 1999
            • 1434
            #20
            Re: Just curious
            Does the tube bottom out against an internal lip on the block or does it depend on a shoulder on the tube?
            If it's a shoulder on the tube, how about this?
            Use a long pan head bolt just small enough to slip down the tube remains, clamp it really REALLY tight in some vise grips, then using a block of wood or whatever you can use for a fulcrum (did I spell that right? ) apply pressure to force the tube upward.
            The flat face of the bolt head might just be able to grab the tube edge and cheat it up far enough to grab onto. If you try this, just make sure that you don't reef on it too too much or you might risk popping the bolt head off.
            Now as the tube is extreemly thin, you might have to experiment with just catching the edge if the end is flush with the inner block surface.
            A cheap fix if it works.
            Chuck
            • Chuck R.
              • April 30, 1999
              • 1434
              #21
              Re: Just curious
              Chuck
              • Scott G.
                • August 31, 1984
                • 132
                #22
                Thanks, I purchase a 10mm bolt today. Now I need to get a 10mm x 1.5 tap.
                • Scott G.
                  • August 31, 1984
                  • 132
                  #23
                  • Joel M.
                    • May 31, 1975
                    • 141
                    #24
                    Scott----- that would be 10MM X 1.25 thread pitch -Regards /Joel Miller
                    • Joel M.
                      • May 31, 1975
                      • 141
                      #25
