68 Wiper Motor - NCRS Discussion Boards
68 Wiper Motor
  • Kevin Whiteley
    68 Wiper Motor
    My 68 coupe currently has the SERVICE replacement wiper motor (4918712) with Julian date 79, year 1974. On the motor is a black plastic cover (4961229). From information in the archives, I believe this plastic cover was only temporary.
    Q1: Was this cover supposed to be removed and a washer pump installed?
    I don't have the washer pump, so-
    Q2: What is the correct washer pump number?
    Looking through the AIM, I found the Wiper Motor Assembly is 5044683.
    Q3: Is it correct that the 5044683 is a combination of the 4918712 motor and washer pump? And if so, would the sticker on the motor reveal the Assembly number or the Motor number?
    Re: 68 Wiper Motor
    Kevin-----
    1) Yes, the plastic cover was supposed to be removed and replaced with the washer pump assembly;
    2) The original, correct washer pump was GM #4918474. It has been discontinued for 35 years. A functional, but not "correct", pump assembly is still available from GM under GM #12494836;
    3) The C3 motor assembly is usually identified with a silver label which has the part number for the PRODUCTION assembly and date code (i.e. motor with pump; "5044683"). The motor and pump assembly was never available in SERVICE. However, I'm not completely sure that 1968 used this sort of label. 1969 and later did, for sure.
    • Kevin Whiteley
      Re: 68 Wiper Motor
      Joe,
      If I understand correctly, with respect to PRODUCTION only, the Assembly (both the motor and pump) would have constituted p/n 5044683? Or in other words, 5044683 consisted of two other part numbers, those being 4918474 and 4918712.
      Was it a common practice to take two separate items, each with its own unique part number, combine them and give the new "item" a different part number?
      As always, thanks.
        Re: 68 Wiper Motor
        Kevin-----
        What you describe is correct; the combination of 2 components with seperate part numbers resulted in a third component with a different part number. This is a quite common occurrence in the "world of GM parts". Every ASSEMBLY is made up of parts with individual part numbers. In this case, the part numbers for the 2 assemblies "lose their identity" and become, together, the part number for the "assembly of assemblies".
