'66 300HP WITH K19 CARB IDENTIFICATION - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    I'm being told that the original carb on a '66 small block with K19 (California smog) has a list#3605, as opposed to the numbers in the judging manual as well as the Noland Adams book. Can anyone verify the correct #s for this application?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: '66 300HP WITH K19 CARB IDENTIFICATION
    i'd check with ray morrison, 66 team leader, before purchasing any hollys. mike
    • Kevin M.
      • November 1, 2000
      • 1271
      Check with Carl R Sanger he just restored a 66 A.I.R. car.
      Kevin
        Rob-----
        Every reference that I have, including GM-sourced references, indicate that the carburetor used for 1966 Corvettes with 327 (both 300 hp and 350 hp) and K-19 used carburetor GM #3890499 aka Holley 3605A. In addition, the AIM shows this as the carburetor used. The NCRS spec guide that I have shows the 3605A, too.
        The carburetor mentioned in Noland Adams' book is the GM #3883821 aka Holley 3416A. I can find no information that GM #3883821 was ever a released part number. Also, I can find no record of the existence of the Holley 3416A.
        It's possible, considering the part number, that the 3883821 aka Holley 3416A was used on early 1966 327s with K-19. If so, I can find no record of it, though.
        • Clem Z.
          • January 1, 2006
          • 9427
          holley does not even show a 3416 the list numbers
          go from 3411 to 3417 with nothing in between
          • Mark G.
            • March 1, 2001
            • 227
            • Rob A.
              • December 1, 1991
              • 2126
              Thanks for the response...The one I'm looking at has the # 3890499 DP (I don't know what the DP is for) with a date of 023, which doesn't make sense to me.
              • Rob A.
                • December 1, 1991
                • 2126
                I appreciate the information, thanks...
                • Gerard F.
                  • June 30, 2004
                  • 3803
                  Rod,
                  The DP at the end is part of the correct part number for the 3605 Holley for a 1966 Corvette 327/300HP or 350HP. The date code 023 means 3rd week of February, 1970. So it must be a Service Replacement.
                  Info from "Chevrolet by the Numbers"
                  Jerry Fuccillo
                  #42179
                  Jerry Fuccillo
