HELP ...SOS...63 installtion of rear window trim - NCRS Discussion Boards
  • Collin MacDonald
    On final steps of frame off of 63 Corvette Coupe. I am now stumped on the installation of the trim around the windows on the coupe. I purchase the rubber from Corvette Rubber and the trim clips from Long Island Corvette. Ok so now I go to install the trim and the rubber seems to be to thick as the trim is unable to clip, the rubber pushes against the body panels and the clips seem to be to short. OK now...its obvious all trim clips are not created equal. So what is the BEST clip to use...who sells the best clip? Is there rubber flashing that is thinner? Whos sells it? PLEASE help me I am just stuck. I am going to remove the windows and start all over again, but this time want to buy better products...PLEASE help MANY THANKS
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: HELP ...SOS...63 installtion of rear window tr
    Welcome to this board Collin,
    If anyone knows the answer to your dilema, it will be someone here.
    Good Luck,
    tc
    • mac peppers
      get ready to lose you religion collin, i just finished the same thing and the rear window trim was the hardest part of the restoration. i don't know how to put in a picture so send me you emil address and i'll send you a picture of a clip i found that works great.
      mac
