Does anybody have any tips for dealing with stripped out screw holes in sheet metal? The holes in the windshield frame used by the screws attaching the outside windshield stainless trim are stripped out. I know of one trick which is to insert a small piece of wire into the hole with the screw. Does anybody know of any other methods?
stripped screw holes
Re: stripped screw holes
Rob,
I assume you mean the kind of anchor typicaly used to secure screws in sheetrock. I doubt if one could install one of these without enlarging the hole first to accomdate the anchor.
Once it's in however, I think this would work fine. If not, then remove it and weld the hole like Mikie sez.
Your idea is a good one to try before draging out the welder to burn down the car.
tc- Top
