This is probably a dumb question. Several catalogs I have seen list as applicable to a 67 SB something called an exhaust donut sleeve. It looks like a short 2" or so piece of exhaust pipe swaged down on one end. I know what the heat riser is for, and I know about the FI heat riser plates without an actual valve, and I know what the donut packing is for to seal to the exhaust manifold. What the heck is this other piece for??? Were they installed on every car on both sides?
What is an "exhaust donut sleeve" used for?
Tags: None
- Top
Re: What is an "exhaust donut sleeve" used for?
OK, so help me out since I obviously aren't familiar with it. Does it slip into the exhaust pipe and then the packing goes around it, then the whole thing slides into the exhaust manifold? Is this a required part or just a part that isn't really needed and is often left off? I am just amazed that I have never seen one...- Top
The sleeve also reinforces the I.D. of the donut; the chamfers on the manifold surface and on the flange on the exhaust pipe squeeze the O.D. of the donut inward when the nuts are tightened, and without the sleeve, the donut will disintegrate in short order.- Top
When I first purchased my 396 in 2000, it kept blowing out the donuts and I couldn't figure out why. Then I learned about the "donuts".
It was quite exciting doing a full-throttle redline blast, and then have the donut blowout. You'd think a bomb went off.1969 Riverside Gold Coupe, L71, 14,000 miles. Top Flight, 2 Star Bowtie.- Top
Re: exhaust donut sleeve
Buy the new ceramic ones. They work great and don't disintegrate. The part number should be in the archives, or maybe Joe L has it.
PatrickVice-Chairman (West), Michigan Chapter NCRS
A picture for the words:
Attached Files- Top
I think the ceramic ones are originally intended for recent build GM trucks. Joe L gave me the part number 2 years ago when I replaced my exhaust. They still appear as-new.
For some unknown reason, the sleeve was ...
not part of sidepipe assemblies, as delivered or OTC. All regular front (under) exhaust pipes I've seen have the sleeve integral (crimped or tack-welded) to the pipe in the exhaust manifold flange area. This is why we see sleeves show up ONLY on the AIM N14 sheet.
The real question is why the sleeves were not part of the sidepipe assy.- Top
Yes, you're correct. I see you posted the numbers above.
