C3 Control Arm Bushings (1972) - NCRS Discussion Boards
  • Bill B.
    • September 30, 2002
    • 351
    I tried the archives and did not find exactly what I was looking for on bushing installation. I will be installing all bushing in next couple of days and want to make sure things are right the first time! My specific question is: what exactly determines how far the bushings are pressed in? Do you stop when the inner sleeve contacts the shaft ridge or is there something else which guages it?
  • Chuck R.
    • April 30, 1999
    • 1434
    Re: C3 Control Arm Bushings (1972)
    Hi Bill,
    I pressed mine in until the bushing flange bottomed out against the control arm.
    I ensured that I had a piece of bar stock filling the air gap between the two bores so as not to squash them together.
    Chuck
