The prior owner installed new gas tank using the old straps. The problem I'm dealing with is the filler neck is not properly positioned in the fill access area. The tank assembly is approx/ 1/2" to far forward. It's enough that the gas spill boot around the filler neck is noticeably distorted.
Looking at the AIM there doesn't appear to be any dimensions provided for tank placement.
Is it guided primarily by the strap and bolt arrangement with the mounting bracket? Should there be enough play in the straps and lip on the cross member to move the tank forward 1/2"
Gary
Gary
