C2 Exhaust bracket? - NCRS Discussion Boards
C2 Exhaust bracket?
  • Justin N.
    • February 1, 2004
    • 318
    C2 Exhaust bracket?
    Dear Members,
    If I switch from my stock 67 sb exhaust system to a 2 1/2", can I still keep the original bracket? Do I have to get a 2 1/2" bracket instead, or can I crush the exhaust clamps around this one? Thanks!
    Justin #41362
    Re: C2 Exhaust bracket?
    Justin-----
    Could you do what you suggest? Yes, you could. What you'd end up with is a mess, though. The 2-1/2" pipes will not fit into the radius of the 2" bracket "yokes". So, if you used this bracket, just the edges of it would contact the 2-1/2" pipe and "bite into" the pipes. And, that's just ONE of the problems that would be created.
    Forget it. The bracket is GM-discontinued but available in reproduction and not all that expensive. It's not that hard to change, either. Plus, these clamps do have a service life and who knows how much is left in yours, anyway. What happens to them is that the curved section of the clamp which contacts the exhaust pipe becomes through-hardened due to the extreme heating and cooling cycles it experiences. Consequently, it becomes brittle and breaks off the rest of the bracket. Then, you need a new one, anyway.
      Justin-----
      • Dennis D.
        • March 1, 2000
        • 1071
        Justin
        Tried that on my 70. Didn't work. Ordered the 2 1/2" bracket from paragon. BTW the exhaust got so distorted from the 2" bracket, I had to weld at that location to get it to seal. Posted further down on the nightmare of trying to remove the trans without removing the exhaust. Good luck
        • Dennis D.
          • March 1, 2000
          • 1071
          Justin
          • mike geary
            Justin:
            You have mail.
            • mike geary
              Justin:
              You have mail.
              • Wayne K.
                • December 1, 1999
                • 1030
                Joe, shouldn't Justin's car have come...
                with the 2 1/2 inch bracket. His car is a 300hp 4speed and I thought the only 67's with 2 inch bracket were automatics.
                Wayne
                • Wayne K.
                  • December 1, 1999
                  • 1030
                  Wayne
                  • Scott Marzahl
                    Re: Joe, shouldn't Justin's car have come...
                    I believe all small block 67's came with 2 inch manifolds regardless of HP or transmissions.
                    • Scott Marzahl
                      • Wayne K.
                        • December 1, 1999
                        • 1030
                        Scott,
                        You are correct about the manifolds. The bracket in question relates to the size of the exhaust pipe.
                        Wayne
                        • Wayne K.
                          • December 1, 1999
                          • 1030
                          Scott,
                          Wayne
                          • Scott Marzahl
                            Wayne, sped right through that one..
                            So that I understand, would the pipes change to 2 1/2 inches after the manifolds for different engine/trans applications?
                            • Scott Marzahl
