I picked up a car that was advertised as an LS-6. All of the engine components had matching #'s. All were the right suffixes and had casting dates prior to when the car was assembled. The correct heads and intake were there along with the crank, rods, and pistons. The car has a m-21 with the orig. shifter missing. The car has alot of options, they are; leather, ps, pb, 3:73 rear, rear window defog, alarm, and fm stereo. The car had been hit in the pass rear and a crappy job was done on the repair. So the gas tank had been out before, and the build sheet was missing. The fellow I bought the car from was selling it from his relatives estate. He assured me that his relative was the original buyer of the car in 71. The buyer moved from TN to GA in 81. So the GA title only goes back that far. The seller said the car hadn't run in 25 years, and it shows. the odometer shows 41,000 miles. And the motor on the inside shows that to be true. The front coils still had the HV stickers on them. I think those are from BB with AC.
So I guess what my question is. Is there any way to tell if this is a real LS-6? The numbers match but everything else is missing. The emission data sticker on the fire wall is there. But I don't know if they are different for the different motors. The correct Tach is there but no data plate on the inside console. So any help on this would be greatly appreciated. It seems like a great mystery.
