I am in the process of removing the differential on my 69' coupe for rebuilding.
It looks like I need to remove the 2 bolts that hold the differential crossmember to the frame. Since I don't think these bolts have ever been removed, do I need to worry about these bolts snapping off in the frame? From what I can tell, it doesn't appear that there is a way to access the back of these bolts to spray some WD-40 type lubricant. Are there any special 'tricks' to this? The last thing I want to do is snap these hardened bolts in the frame.
I want to drop the IRS with the spring and crossmember as a unit and remove those items once I have it removed from the car.
Any tops or advice would be greatly appreciated.
Thanks!
Thanks!
