I recently purchased a 1969 L-88 Coupe with an automatic transmission. Today I took it in for the mandatory Arizona emissions test and I failed the hydrocarbons @ idle test (my car measured 1703 PPM vs. the 450 PPM which is passing). The other tests (HC under load, CO under load and at idle) were passed with flying colors.
My problem is that I have zero experience with L-88s, or any big block, for that matter and therefore don't know what to expect. Should this car be able to pass this test? The documentation I got with the car, and the research I've done so far indicate that this is a very well restored car (it's a 98.6 pt. Bloomington Gold car, no NCRS flight yet but I'm hoping to prep the car for that too). In my mind this means that the car SHOULD be running as designed. It may not be, but I just don't know.
Any thoughts out there on what I can/should do to pass this test? I can't even title the car in Az without passing this test.
Thanks, Jon Strachan jonstr@speedchoice.com NCRS member #10673
