Hi All,
Have a '64 with stock 327 except for a new Edelbrock intake and 600 carb. I had to add a 1" adapter between the carb body and the air cleaner to utilize the stock air cleaner.(it needed to be offset foward to clear the ignition shielding.) Engine runs strong except after the car has been turned off and sitting for a while, then it is very difficult to start. After cranking for a bit it fires, although dogedly, belches a bit of black smoke, like she's flooded, and then runs well. I've also noticed that occasionally, while at idle, the rpm's fall slightly and she almost stalls. Any help will be greatly appreciated. Thanks, Randy
