Re: '64 HARD STARTING WHEN EGINE HOT
Since the '63-'65 300 hp auto and the '66-'67 300 hp all used 2 inch exhaust and the cam for the 250 hp and 300 hp was the same, those are not the reason your car was flooding.
A carb is an on-demand item. It cannot force more air or gas in unless it is broken. Then it will force more gas in due to leaking or will allow more air due to leaks. So you can put a huge carb on or a small one, and they wil both run with some conditions. One too big will end up bogging due to the engine being unable to pull enough air to keep the airflow speed high enough or may flood because the accelerator pump is too great, forcing raw gas in. But sitting idling hot will not flood just because it is bigger. And a 600 cfm is not really big.
