c1 spark plug wires - NCRS Discussion Boards
c1 spark plug wires
  • PAUL BOWERS
    c1 spark plug wires
    have 57 single four, and am considering buying new plug wires
    do I have to purchase them thru vetts catalogs like c.c. , dr. rebuilt
    aren't 283's all alike and be purchased at a good auto supply
    are do the vetts plugs have (special) markings if so what are those characteristics and where have you had good luck aquiring them
    thanks
    Paul
  • Roy B.
    • February 1, 1975
    • 7044
    Re: c1 spark plug wires
    The cost is $67.00 from C&C the ends are orange color that's about the difference and not dated.
      Paul-----
      It all depends what you're after with the wires. If you want exact original in every nuance of detail currently available, then you should buy a Lectric Limited (or, other) reproduction set.
      If what you're after is functionality, then you have a LOT more options available. For example, you could buy a Delco plug wire set from any Delco distributor. These sets have the spark plug boot end already installed on the wires; you cut each wire to length and install the distributor end. Delco also makes a wire set which is "plug-and-play". I believe that these are specific to Corvettes due to the special length wires used. I'm not absolutely sure if these are available, or not, anymore, but they're what I prefer.
      • Christopher R.
        • March 31, 1975
        • 1599
        There's some on EBay right now. They're Motorcraft wires. I believe you can wipe the wires with a lacquer soaked rag to wipe off the Motorcraft writing. $10.
