C2 speedo cable routing - NCRS Discussion Boards
  • Randy S.
    • January 1, 2003
    • 586
    I recently replaced my 66 manual trans speedometer cable. The replacement cable is about 71" and my original cable was 66". I was not able to locate any shorter cables and most seem to be in the 71" range. The problem I am having is the excess length causes the cable to drop down and rest on the exhaust. Not good.
    I have used all the clips on the firewall I can find but I still have excess cable slack.
    Has anyone been down this road??
    Randy
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C2 speedo cable routing
    Randy,
    Try to make a small loose loop and hide it under the dash directly behind the speedo.
