If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Ihave a 1959 Corvette... All the numbers match.. However when I got the car someone put in a Mallory uilite dist.
When the engine is at 2000 RPM's, the tack is reading 4000 RPM'S...
Can someone tell what I need to do to fix this?
Unless your car was originally a fuelie, the tach was driven off the generator. It turns at engine speed, while the distributor turns at half engine speed. Suspect you have a wrong combination of parts. The tachs are calibrated differently for each application. A speedometer repair shop can probably recalibrate your mechanical tach.
It could be something as simple as someone has put a very small generator drive V-belt pulley on. The correct pulley has a 3 1/2" to 4" diameter. Take a look.
Brad
Or, it was originally a fuelie (distributor-driven tach) and is no longer, and now has an engine-speed generator driving the original half-speed tach head, so it reads double engine rpm. Or, someone changed the tach and installed the wrong one and didn't want to go through the exercise of changing it a second time. Bubba is everywhere
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
