1959 Corvette
  • Joseph Harrah
    #1
    1959 Corvette
    Ihave a 1959 Corvette... All the numbers match.. However when I got the car someone put in a Mallory uilite dist.
    When the engine is at 2000 RPM's, the tack is reading 4000 RPM'S...
    Can someone tell what I need to do to fix this?
    Joseph Harrah
  • Pat #25912
    Re: 1959 Corvette
    Is the tach the original mechanical unit or is it an aftermarket electronic unit? Pat G.
    • Ed Jennings
      Re: 1959 Corvette
      Unless your car was originally a fuelie, the tach was driven off the generator. It turns at engine speed, while the distributor turns at half engine speed. Suspect you have a wrong combination of parts. The tachs are calibrated differently for each application. A speedometer repair shop can probably recalibrate your mechanical tach.
      • Brad K.
        • September 1, 1990
        • 413
        Re: 1959 Corvette
        It could be something as simple as someone has put a very small generator drive V-belt pulley on. The correct pulley has a 3 1/2" to 4" diameter. Take a look.
        Brad
          Re: 1959 Corvette
          Or, it was originally a fuelie (distributor-driven tach) and is no longer, and now has an engine-speed generator driving the original half-speed tach head, so it reads double engine rpm. Or, someone changed the tach and installed the wrong one and didn't want to go through the exercise of changing it a second time. Bubba is everywhere
          • Michael D.
            • September 1, 2001
            • 0
            Re: 1959 Corvette
            send the tach or the guts to roger scott 561 627 9345. he can recalibrate it or totaly refurbish it.
