66 Power Window Harness Routing - NCRS Discussion Boards
  • Mike S.
    • September 30, 1999
    • 91
    What is the correct routing for the harness? The assembly manual appears to indicate it leaves the switch on the right, travels diagonally down and forward across the tunnel, and then follows the floor/tunnel junction up to the firewall. However, it looks like a better and simpler route would be under the edge of shifter console. Which is correct?
    Mike S
    #33053
