(Message Deleted by Poster) - NCRS Discussion Boards
  • Hal Pringle
  • William O.
    • April 30, 2001
    • 355
    Re: What size tires for C2
    For driving, I use Michelin P 215/65.
    works well.
    Bill
    • Andy F.
      • January 1, 2004
      • 93
      Mine are 205/75R-15...look right to me and no rubbing.
      • James W.
        • December 1, 1990
        • 2640
        Hal,
        Andy is correct, the correct replacement size tires for a 6.70x15 is a 205/75-R15 radial tire. I am running a low dollar 205/75-15 General tire brand blackwall radials on my '64 convertible. I've heard really good things about the Michelin brand Harmony blackwall radial tires also. They are said to be a quiet, smooth riding tire. The revs per mile for the 205/75-15 size tires are comparable to the OEM 6.70-15, less than 3% difference so the speedo should be right on. If you want a whitewall tire there are plenty of them out there in the 205/75-15 size. I don't like whitewalls on C2 Corvettes so I went with the blackwalls. Go to www.tirerack.com and search for tires by size. You should get a pretty good selection to choose from.
        James West
        Omaha, NE.
          • 15610
          I recommend a higher speed rated/higher performance tire than a 205/75. This is satisfied by the 215/70R-15, which are available in speed ratings as high as "W". Revs per mile are within two percent of the OE 6.70-15 value of 760. The 5.5" wheel width is a bit narrow, but is within the acceptable wheel wide range.
          The Tire Rack web site listed previously is a good place to survey the available makes and models within any size group. Click on "shop by size" and input the suggested sizes.
            If you're just cruising and don't necessaruly need a speed-rated tire, Firestone has a new "Supreme Si" series of radials, and they're available in the 205/75-15 size in both blackwalls and whitewalls.
              Oops, fat-finger typing - should be "necessarily"
